Removing Glue from a DVD
Discussion in 'DVD' started by Ravi K, Jun 13, 2005.
  1. Ravi K
    Ravi K Supporting Actor
    Feb 24, 2003
    707
    I have a used DVD with a circular paper sticker stuck around the hole, and I want to remove it before I play it. What would be the best way to remove the residual glue without damaging the DVD? What about isopropyl alcohol?
  2. Eric Peterson
    Eric Peterson Cinematographer
    Aug 2, 2001
    2,959
    Is it on the play side or the label side?
    I often use "Goo-Gone" to remove the residue on the case, and I'm sure it would work fine on the art side of the disc, but I've never tried it on the disc itself, and never on the play side.
  3. Ravi K
    Feb 24, 2003
    707
    Its on the art side.
  4. Harold Wazzu
    Harold Wazzu Supporting Actor
    Oct 1, 2003
    885
    I often use a piece or two of masking tape and tap it repeatedly on the residue, that usually works for me.
  5. Alex-A
    Alex-A Stunt Coordinator
    Dec 23, 2004
    211
    I will recommend Goo-Gone for anything sticker related. I bought a used DVD a while back form a place that likes to put their stickers around the hub that leave the word Void behind several times if you pull the sticker off. GG took it right off, no damage to the artwork whatsoever. The stuff works miracles.
  6. Mark Zimmer
    Mark Zimmer Producer
    Jun 30, 1997
    4,300
    40
    Just be very careful not to scratch the artwork; you'll likely damage the data layer if you do so. These things must be done delicately....
