Removing Duct Tape Marks From Carpet?
Discussion in 'Archived Threads 2001-2004' started by Chuck C, Jan 18, 2003.
  1. Chuck C
    Chuck C Cinematographer
    Jan 6, 2001
    2,224
    I duct taped some wire down to our burbur carpet, and when I removed it, it left residue and an indentation where the wire used to be. Is there a way to remove this type of stain w/o calling the pros?
    thanks
  2. HienN
    HienN Stunt Coordinator
    Jul 4, 2002
    144
    Try ice. Depending on the kind of tape you used, sometimes the adhesive will "ball up" when cold. You can then rub it off the carpet (It's worked for me on walls, but I've never tried it on carpet).
  3. Bill_D
    Bill_D Supporting Actor
    Dec 10, 2001
    755
    Try "Goo Gone". It is excellent on sticky residue.
  4. David Von Pein
    David Von Pein Producer
    Feb 4, 2002
    5,748
    10
    Goo Gone on your carpet? I'm not too sure I'd want to try that.
  5. Chuck C
    Jan 6, 2001
    2,224
    I tried goo gone...does not work
  6. Bill_D
    Dec 10, 2001
    755
    I have used Goo Gone on carpet several times with great success. I have a 4 year old and Goo Gone is my friend.
  7. Bill_D
    Dec 10, 2001
    755
    OK, the other stuff I use is Goof Off. It is considerably stronger than Goo Gone. I would heed David's warning with this stuff though. I know it will work but I would start with a watered down solution first.
  8. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,460
    338
    9,110
    Cees Alons
    Chuck,
    I often use another piece of duck tape to sort of pick up the residue. And if that piece doesn't stick anymore, another, etc. [​IMG] It works almost all the time.
    After you manage to get it clean, try using a vacuum cleaner to remove the indentation (and/or some help from your thumb-nail moving in a anti-scratch movement - the movement that presses the nail to the thumb instead of the other way, I hope I do make clear what I mean).
    Don't try to get the indentation away totally in one attempt. Regular vacuum-cleaning may do the rest of the trick.
    Good luck,
    Cees
  9. David Von Pein
    Feb 4, 2002
    5,748
    10
  10. Chuck C
    Jan 6, 2001
    2,224
    oooo, good suggestions...will try tomorrow
  11. Chuck C
    Jan 6, 2001
    2,224
    Wow...GOOF OFF! not only did it remove the duct tape marks with ease, it also removed heavy, black gum stains and latex paint that's all over the beautiful 1½ century old wood molding.
  12. Bill_D
    Dec 10, 2001
    755
    I told you ..........
    If you want to know how to get a self-portrait fashioned in Crayola markers on a canvas of the Living Room carpet, let me know.
  13. Chuck C
    Jan 6, 2001
    2,224
    bill...hahah, thanks again. I was at Wal-Mart, and I was origianlly there for x-acto blades. So I'm in the hardware section when I see the Goof Off. Immediately, I remembered this thread and picked up a can. Man, it smells worse than paint thinner. My housemates came downstairs complaining of the smell. By then, I was in a different place [​IMG] [​IMG] :wink:. Nevertheless, the performance negates the smell BIG TIME.
  14. Lee L
    Lee L Supporting Actor
    Oct 26, 2000
    868
    Another removal tip taught to me by a carpet installer. If you have a piece, use a scrap of the carpet you are cleaning to remove the stain. That way, there is much less of a chance the dye could transfer out of th ecarpet and onto your rag, causing a light spot.
    Also, never pour the Goof Off directly onto the carpet, always pour it onto the rag or scrap piece. It will cause the backing to break down.
