Remote programming problem
Discussion in 'AV Receivers' started by Joey Skinner, Oct 12, 2003.
  1. Joey Skinner
    Joey Skinner Second Unit
    Sep 12, 2003
    339
    I have a H/K AVR 225 receiver and I can't program the remote to work my Sony SLV-N60 VCR. I tried direct code entry and auto search method. I had no problem programming the remote to work my TV or DVD player. Is it possible that my remote just won't work with this VCR?
  2. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    It's very possible that the code for your VCR does not reside in the memory of the remote you are trying to program. Out of all the receivers I've owned over the past 3 or 4 years, I've never been able to utilize the factory remote to control all of my gear. This is why the aftermarket remote control business is booming.
  3. Keith*D
    Keith*D Agent
    Sep 14, 2003
    48
    Make sure you are trying to program it into "VID 1" as that is the only one that will accept the VCR code. If that doesn't work then call HK, they have been very helpful to me.
    Keith
