Remote for projector......
Discussion in 'Accessories, Cables, and Remotes' started by AndyGas, Aug 11, 2005.
  1. AndyGas
    AndyGas Extra
    Jul 16, 2004
    17
    Apologies if this isn't the right place to post in but I can't seem to find anywhere appropriate for my question....
    I have an NEC Multisync MT1030+ projector with no remote.
    Does anybody know where I can get a replacement remote for it for less than $114 which I think is a bit steep for a remote. They must also offer delivery to the UK.
    Failing that.. Are there any Universal remotes around which can be programmed to operate projectors??
    I'm looking to encase my projector but I will not be able to operate it using the on-board buttons if I do.
  2. Bryce_H
    Bryce_H Stunt Coordinator
    Oct 20, 2004
    116
    10
    I got a Logitec Harmony remote 676 and it works with my old sony projector with no problems. I bought it when I got a Denon 3805 that didn't have a remote. All the codes are downloaded off the internet, so you do not need the orignal remote to program it.
