Remote Dimmer
Discussion in 'Accessories, Cables, and Remotes' started by Rick Thoms, Mar 12, 2005.
  1. Rick Thoms
    Rick Thoms Agent
    Feb 21, 2003
    31
    At Home Depot they have a remote control dimmer ,not sure of the brand. It's about 68$can and I was wondering If you can program a universal remote to act like the one it comes with, thanks.
  2. Darren Mortensen
    Darren Mortensen Stunt Coordinator
    Jul 26, 2001
    232
    You are speaking of the Lutron. If you have a learning remote you use it to control this dimmer.
  3. Adam Gregorich
    Nov 20, 1999
    15,837
    728
    9,110
    The Other Washington
    Adam
  4. Darren McGruther
    Darren McGruther Stunt Coordinator
    Jul 25, 2001
    87
    great dimmer. I'm using it in my theater and I have it running through my Sony remote, works great
  5. Rick Thoms
    Rick Thoms Agent
    Feb 21, 2003
    31
    I'm wondering are they all on different codes. If I buy 2 can I control them seperatly.Thanks. I have the MX500 remote.Also does this dimmer have memory settings you can go to?thanks
  6. Brad E
    Brad E Second Unit
    Jan 11, 2004
    304
    Rick, the dimmer in question, (I can't remember the product #) is pretty much the cheapest remote dimmer that Lutron makes.
    All codes are the same, but you pretty much need to point the remote directly at the dimmer switch. So you could control two switches individually in the same room if they were placed in different locations.
    It will remember the setting you left it at, but that's it.
    When you turn off the lights you can either choose a 3 second or 10 second delay.
    All in all, it's a very good dimmer. Suits my needs perfectly and super easy to install.
  7. DustinT
    DustinT Agent
    Nov 29, 2004
    44
    I would make one suggestion.
    Do not put the same setup in more than room if your remote has the capabilities of sending signal without actually being pointed at the device.
    The house we moved into a year and a half ago has a remote light dimmer/on/off set up in the downstairs (t.v. room) and up stairs bedroom. it is a poor quality one for sure. hit the button down stairs and all the sudden the light upstairs is going on and off.
    Also, it requires the light switch to be on for the remote to work, but if you flip the light switch on, you still have to use the remote to turn on the light. if you lose the remote you lose the light. it blows.
    I'm sure this is a very low quality (and old) setup, i have read about better setups on home-automation sites, so i'm not trying to scare you away completely, just warn [​IMG]
  8. Orlando
    Orlando Stunt Coordinator
    Aug 1, 2000
    208
    I'm using the Lutron as well and it is great. I have a learning remote One for All Kameleon that I "taught". definitely worth it.
