Remote Control Help. Equip In diff room
Discussion in 'Accessories, Cables, and Remotes' started by Ryan*D, Oct 17, 2005.
  1. Ryan*D
    Ryan*D Agent
    May 15, 2005
    30
    Hello
    I'm about to set up my HT.
    THe problem Im haveing is going to get the remote to work.
    The equipment is going to be across the hall. I cant see it from where I will be sitting.
    I also need it to work in the HT also. I have the Lutron Grafik eye going in. That is sitting behind me as well as the projector.
    I was going to use the phillips pronto pro.
    I know they have a ir to rf to ir adapter but that might not work. The Equipment is going to be flush with the wall its in. I can't have anything on the ceiling or across from the equip.
    So what should I do?
    This is the only thing Im stumped on.
    Thanks for any help
  2. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Ryan I sent you an email with some more specifics but essentially I'm using a Xantech hidden link unit to solve the same problem you have in my own media room.
