KSimmons
- Aug 9, 2006
- Kevin
My old cheap but trusty OFA remote has no code for my Toshiba HD-A2, so its time to start shopping. I am leaning toward the Harmony 550 for the activity buttons.
So, when I press the activity button it will turn on or off the needed/unneeded devices and switch the amp/rec to the appropriate input, right? I think that part is easy enough. But, it will also need to switch sources on the TV. The TV does not have direct access to each input like the amp does. Is there some slick way that these remotes handle this?
On the TV I have a button that scrolls thru component1, component2, HDMI and Antenna and a completely different button to switch between 4 different S-video/composite inputs and Antenna.
I could use component only and let the receiver do all the switching but I still have the VCR that is used occasionally and my kids gamecube. These are either S-video or composite and my rec will not convert them to component. So, even if I stop using HDMI(which my rec doesn't handle at all) I will still have some problems.
Not that I can buy one any time soon but is there a receiver that will convert composite and S-vid to HDMI?
Thats may be too much info but I wanted to make my situation as clear as possible. Thanks for reading.
