regular power-strip + surge strip = ???
Discussion in 'Archived Threads 2001-2004' started by Ted Lee, Dec 1, 2002.
  1. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    hi all -
    kind of a weird question i guess...
    if i hook up a regular power strip (no surge protection) to another strip (*with* surge protection) will that work?
    would i "effectively" create a second protected surge strip?
    thx,
    ted
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    yes but just keep in mind not to create an overloaded situation. Ted, if that's one of those little $5 plug in the wall things, I wouldn't count on it having much stopping power as you're likely to maybe have one little MOV in it.
  3. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    thanks chu.
    i've actually got a couple of good surge strips (one by isobar, can't remember the other one). i was in an "emergency" situation and did the above config.
    i thought it would work, but wasn't 100%. it's probably not something i would do as a permanent setup.
    have a good one!
