Registry error
Discussion in 'Archived Threads 2001-2004' started by Miles Lucasso, Feb 20, 2003.
  1. Miles Lucasso
    Miles Lucasso Stunt Coordinator
    Jan 12, 2002
    101
    Hi all-
    I know I saw a post on the forum about this, but I can't find it.
    I changed my memory from 32meg to 128meg on an older windows 95 os system. And now get a registry error everytime I start it.
    I swapped back in the 32meg and problem went away.
    Anyone know how to keep this from happening?
    -Miles
  2. Glenise
    Glenise Supporting Actor
    Feb 5, 2001
    773
    2
    Are you able to run your pc in safe mode?
    If so, what do you get when you click on control panel, system.
    Does it registr 128mb of ram being in the system?
  3. Miles Lucasso
    Jan 12, 2002
    101
    Thanks for the reply-
    Yes, I was able to start the computer initially, and it said the system had 128 mb ram.
    So it would seem that it accepted the ram ok.
    But the registry screen won't let me move past it, I have to shut it down and then it pops back up again.
    -Miles
  4. Wayne Bundrick
    Wayne Bundrick Cinematographer
    May 17, 1999
    2,358
    The system might recognize the particular amount of RAM but the RAM can still be defective.
  5. Miles Lucasso
    Jan 12, 2002
    101
    Wayne-
    Although the ram was bought new, I think you may have a point in that it is not exactly the same as that in the system.
    The computer is an older windows 95 running 100 pin 66mhz sdram
    I could not find 66mhz anywhere. I put in 100mhz thinking it would simply run at 66hz speed.
    But it seems it may not be completely compatible.
    -Miles
