Region Free Question
Discussion in 'DVD' started by Dustin Bacon, Dec 4, 2002.
  1. Dustin Bacon
    Dustin Bacon Auditioning
    Nov 19, 2002
    3
    I have taken the advice of some readers on a previous thread, and I have decided to buy a new Region-Free DVD player with PAL/NTSC support.
    Unfortunately, due to the Christmas season, I am on a bit of a budget. I did find the Cyberhome ch-dvd 402 dvd player at a reasonable price of 99 dollars.
    Now I have to ask: does anyone out there know if the PAL/NTSC conversion is any good here? Or will I have the same problem I had with the old Daewoo?
    Sorry if I posted this in the wrong forum![​IMG]
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    You'll have the same issues as the old Daewoo at that price
    Malata, JVC N520(or whatever the model # is) or an HTPC are the best options
  3. Daryl Stovall
    Daryl Stovall Second Unit
    Oct 4, 2002
    455
    Are The Sampo Models Any Good?
  4. Jeff Kleist
    Dec 4, 1999
    11,267
    No
    If you're paying less than about $2-250 for a PAL converting player, it's a piece of shit.
  5. JohnAD
    JohnAD Cinematographer
    May 21, 2002
    2,335
    Daryl:
    I recently purchased the Malata DVP-520 player from Next Best Thing Electronics (www.nbtelectronics.com) in Canada. Since the exchange rate is so good, I got the player, with shipping, for around ~$270 US. No major problems, only a few minor nitpicks. The PAL->NTSC conversion is excellent.
    John.
  6. Daryl Stovall
    Oct 4, 2002
    455
    Thanks. Does It Come With An Optical? Also What Were The Nitpicks?
  7. Jeff Kleist
    Dec 4, 1999
    11,267
    Yes, it has an optical and coax out
    There are some incompatibilities with some discs, but they usually upgrade their firmware to fix it lickety split, and it's a matter of burning a CD and flicking a switch to upgrade
  8. Daryl Stovall
    Oct 4, 2002
    455
    I'm A Little Skittish Of Buying Electronics Online. Is It True That Online Purchases Comes Without Warranties?
  9. JohnAD
    May 21, 2002
    2,335
    Daryl:
    I've only had a problem with one disk, and that was the Momentum R2/PAL version of They Live. I'm pretty sure the disk was bad, since my other PAL disks play just fine. I'll know when my replacement arrives next week.
    As for nitpicks, I've only noticed a few:
    1) Some random pixelation every so often. This is the player, since it will happen at different spots on the same disk on different playings.
    2) The remote layout could be better. Much better. I've gotten used to it by now, but when I first got my player, I was rather dumbfounded by the layout of the buttons on the remote. For example, the 'pause' button is far away from the 'play' button.
    3) The manual is a little light, and doesn't tell you everything.
    As Jeff said, the firmware is easy to upgrade, although I've got the latest, so I haven't had to do that yet.
    As for warranties, it depends on where you get it from. Some places will have them, and some won't.
    John.
  10. Jeff Kleist
    Dec 4, 1999
    11,267
    Daryl, you don't have to capitalize every word [​IMG]
    No, that's not true at all. Some manufacturers say they'll only support purcheses from authorized dealers, but in reality it's never really been a problem
  11. Daryl Stovall
    Oct 4, 2002
    455
  12. Jeff Mason
    Jeff Mason Stunt Coordinator
    Jul 8, 2002
    76
    Anyone looking to buy region free and wants to know how good the PAL to NTSC conversion will be should try to find out/ask what the chip inside is. I have a a Daewoo 9000N that I use as a second deck for the Macrovision free feature, but the PAL conversion stinks!
    As far as I know, the Mediamatics chip is the least expensive chip that does a good PAL to NTSC conversion. This chip is found in all Malata and JVC players that you see around that are region free. If the deck is modded and has a Mediamatics chip, it should do a fine job with the conversion.
    For the record, I have a Malata 996 and it does a very nice job on the conversion. Unlike the 520, I've been lucky and haven't seen any visual quirks or had any problems with the deck overheating (as with some 996s).
  13. Luis S
    Luis S Supporting Actor
    May 7, 2000
    637
    Brought the cyberhome500 home tonight.Not too shabby actually and progressive scan too.EASY multi region hack.69.99 at BB $50 after $20 rebate.Good luck.
    Luis S
  14. Ronn.W
    Ronn.W Second Unit
    Dec 16, 2002
    333
    And the CH 500 does do flawless PAL > NTSC anamorphic conversion. It uses a new Cirrus Logic chipset that is comparable to mediamatrics.
  15. Mike_Richardson
    Mike_Richardson Supporting Actor
    Sep 11, 2002
    639
    There seem to be a lot of people on the HTF who haven't even seen the Cyber Home and instantly debunk it because of the price.
    As someone who has owned a Malata, Classic, and a Sampo, this is EASILY the best multi-region player I've seen for the price. The PAL conversion is SPOT-ON, the picture quality is comparable to my trusty old Panasonic, and it was a scant $69 at Best Buy (with an additional rebate of $20, no less!).
    I feel bad for the people who spent over $200 on the Malata when this player does it all almost as well for a FRACTION of the price.
    Don't let the low price keep you away -- DEFINITELY give it a shot. At that price you can't go wrong, and like I said, it's better than any multi-region player I've owned.
  16. Luis S
    May 7, 2000
    637
    Thats for damn sure Mike! I was COMPLETELY impressed with the Cyberhome! Absolutely wonderful picture and multiregion conversion. And heres another plus I discovered last night,NO NOTICEABLE LAYER CHANGE!!!! [​IMG] Amazing! How many players do that AND prog. scan? Only htpc's far as I know! this may very well become my main player if you can belive it.As Mike said dont let the price or cheesy name steer you away,this thing is a keeper!
    Luis S
  17. Daryl Stovall
    Oct 4, 2002
    455
    Does'nt Bestbuy only carry region one players? If so how Does one get it to play other regional dvd's?
  18. Luis S
    May 7, 2000
    637
    Its a "hackable" player Daryl [​IMG] [​IMG]
    Luis S
  19. Amano Ai
    Amano Ai Agent
    Nov 19, 2002
    30
    There is something going on the top of the picture when viewing widescreen movies. Right under the letterbox bar on top. I had to return the 500 because of it.
  20. FredHD
    FredHD Stunt Coordinator
    Oct 8, 2000
    176
    I have to agree with Luis and Mike. This thing is great. The hack is easy, the PAL to NTSC conversion is great, and the layer changes are smoother than my vegan macaroni and cheeze. I love this thing. It is my new main player. My Panny is going into the living room.
