Region free DVD for PC
Discussion in 'Archived Threads 2001-2004' started by Marc_E, Mar 13, 2003.
  1. Marc_E
    Marc_E Supporting Actor
    Oct 9, 2001
    769
    Hi all,
    Is the Toshiba SD-m1712 a region free player? I am building my first HTPC and want to make sure it is.
    System so far:
    ASUS P4PE MB
    P4 2ghz
    1gig PC333
    To be bought:
    Seagate barracuda 120gb HD
    Toshiba SD-M1712B
    ATI Radeon 9500 pro 128MB
    and more
    undecided on case but I am thinking about the new Antec Fusion.
    Marc
  2. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    I dunno if I can say this sorta stuff but it doesn't deal with the direct countering of the copy protections on a disk and regional coding is something I don't believe in so I'll just go ahead and say it.
    I use a program called "DVD Genie" which counters the restriction on the number of times that you can change the region encoding of a DVD-Drive. all DVD drives are supposed to allow for a minimum of 5 alterations to the region encoding before permanently locking but DVD Genie allows for you to change it however many times you wish.
  3. Steve_Ch
    Steve_Ch Supporting Actor
    Oct 14, 2001
    978
    Go to dvdhelp.com (formerly vcdhelp.com) and sniff around, they have list of all these stuff. Generally, DVD drive manufactured before 2000 are safe, else may be. I have a LiteOn, I think it's a 2002 model, and it's region free.
