refurbished audio components
Discussion in 'AV Receivers' started by MichaelBAr, Jan 18, 2004.
  1. MichaelBAr
    MichaelBAr Stunt Coordinator
    Jan 16, 2004
    72
    Wheres a good website to get refurbished goods? Like recievers, subs, speakers, etc.
  2. Ed Moxley
    Ed Moxley Cinematographer
    May 25, 2003
    2,701
    Eastern NC
    Ed
    You can get a little from www.overstock.com
    Maybe someone else knows more places...........
  3. gene c
    gene c Producer
    Aug 5, 2003
    5,854
    54
    9,110
    Bay area, Ca
    Gene
    Ecost.com and pcmall.com and many manufactures sell their own stuff on their web sites such as H/K and Onkyo. There are many others as well. Check Ebay for a bunch more. Gene
  4. TimGRA
    TimGRA Stunt Coordinator
    Dec 29, 2003
    82
    In your search you may also want to use the term "B" stock. Most direct manufactures will use that term.
  5. RobCar
    RobCar Stunt Coordinator
    Nov 27, 2002
    201
  6. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,527
    110
  7. Mark_H
    Mark_H Stunt Coordinator
    Oct 23, 2003
    63
    I got my HK AVR-225 from Soundcity.com
    I highly reccomend this online retailer, they are an authorized HK dealer and I have been very happy with my HK refurb receiver.
    HK gives you a two year warranty just like if the receiver was new so make sure you buy from an authorized dealer so your warranty is honored.
    Harman Audio sells refurbished JBL and Infinity Speakers and also HK equipment. This is "the" factory outlet for these companies and so the warranty would be fine if purchased from there.
    Soundcity and other online retailers frequently beat HarmanAudio.com on price however so check around.
    You can check the HK, Infinity and JBL websites for a list of authorized dealers and then search those sites for the best deal.
  8. Scott Merryfield
    Dec 16, 1998
    15,501
    3,152
    9,110
    Both www.jandr.com and www.onecall.com usually have some refurbished equipment for sale on their sites. You have to look in each category, though, such as receivers, speakers, etc. They do not have a separate "refurb" section of the website.
