Reference Level- for what room size?
Discussion in 'Archived Threads 2001-2004' started by Ryan Cruz, Aug 26, 2002.
  1. Ryan Cruz
    Ryan Cruz Stunt Coordinator
    Apr 2, 2002
    139
    A lot of us have calibrated our systems to reference levels using SPL meters, and most of us find this setting too loud.
    Just what room size is the basis for reference level anyway? Maybe its too loud because the rooms we use are too small.
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    It's the same no matter what, actually. That's the whole idea really, to make it the same in every situation so that ref level at my place is the same as ref level at yours.
    I agree, it's too loud.
    And even though I can calibrate my system, I doubt it can cleanly hit a ref lev peak. Not enough power.
  3. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Yep, ref cal is relative to whatever room your setup is in. "Too loud" at reference level is irrelevant also, since most people do not actually listen at reference levels 90% of the time, I know I don't.
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Guys, Guys.. just because you use 75 db for test-tones does not mean you peg the volume control at this position and listen to movies at this level.
    You adjust the volume for each movie to taste.
    Ryan - if you think about it - if you adjust the volume control in a small room to read 75 db at the listening position, and someone else does this in a large room: which room has the louder sound?
    Neither. The volume in both rooms is 75 db at the listening position. Thats what you use the SPL meter for - to get a known volume. [​IMG]
  5. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    This thread might prove of interest. Note the number who listen at this level.
