Brett DiMichele
- Sep 30, 2001
- Brett
Ok I hear people refer to listening to music and movies at
"Reference Level" and my question is: Is Reference Level the
same on all high end Receivers? For example my Onkyo DS787
states Ref @ 62 (If I am not mistaken) and the volume scale
goes past Ref to 70ish or so.
Ok another thing is Ref is @ 62 is this acheived with all
the channels set to a flat 0Db (L/C/R/SL/SR/SB) ? How would
a feature like "Intellivolume" factor into the equasion?
Since the Onk has this feature and it is adjustable from
-12Db to +12DB.
I am just curious that's all. Is Ref a certain Db like say
100Db? If so then I guess I would need to "Set" Ref using
a Rat Shack SPL Meter to ensure that Ref is accurate?
All I know is at Ref with all channels set to flat 0Db it's
LOUD as heck and it goes anoter 10db past that..
Brett DiMichele
Certified Audio Nut
My Home Theater Site!
[email protected]
-12Db to +12DB.
Brett DiMichele
Certified Audio Nut
[email protected]
