Red Shift problem (not red push)
Discussion in 'Displays' started by Alex Morrow, Jul 20, 2003.
  1. Alex Morrow
    Alex Morrow Stunt Coordinator
    Feb 28, 2001
    165
    My TVL Mitsubishi 65" 16x9 TV WS-65807
    Right now I have a problem when I first start up my tv it looks fine for about 30 seconds then it kicks into red shift mode (not to be confused with red push). Somehow the red gun is out of wack for a while, at first it was only about 3 mins but now it's going over 20mins to switch back and getting longer and longer each time. Here are some photos in the weblink below to better explain what I see on my tv. Is there something I can do or should I be getting a service tech out to my house to fix the problem?
    http://www.geocities.com/vandenberg5/red/index.html
  2. Guy Kuo
    Guy Kuo Supporting Actor
    Mar 6, 1999
    581
    Get a service tech. Sounds like a thermal intermittent failure of a component.
  3. Alex Morrow
    Feb 28, 2001
    165
    I just found out from hometheaterspot.com that this is due to the Convergence IC chip having a bad sodering job on it. Over there they talk about how to removie the chip and fix the problem on your own. It's all a bit complicated, but I'm going to find out first if I'm still under warrenty so I can get a tech to do it or else I'll bring the chip into work and fix it here.
