Red Semi-Circle Lines on Display
Discussion in 'Displays' started by Russell_Latham, Feb 21, 2005.
  1. Russell_Latham
    Russell_Latham Auditioning
    Feb 21, 2005
    3
    I have a Sony KP-51HW40 RPTV. I am seeing when the background is dark, say black or dark blue, there are semi-circular red lines spaced several inches apart that arch on my screen. They are very thin but very annoying. Anybody have any ideas on what this might be.
    Russ
  2. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    There may be some stray red material that is not part of the picture and off the screen due to overscan, but reflecting off of shiny objects inside the cabinet.
    If there is a trap door in the back you can look into you might be able to cover shiny objects with dull black cloth or put electricl tape over parts of the lenses inside so as to eliminate the stray lines but not dim out parts of the picture.
    Video hints:
  3. Russell_Latham
    Feb 21, 2005
    3
    Not sure if I completely follow what you're meaning but this has cropped up suddenly. If I go into the service menu to calibrate and bring up the gird and it turns the picture solid black the image still appears. Calibration did not fix it.
  4. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    sounds like the red CRT is set too high ... turning the red screen trimpot down a bit will make the lines go away ... but the grayscale will need to be rebalanced as a result ...
    regards
  5. Russell_Latham
    Feb 21, 2005
    3
    I think I'll wait until the pro gets there to adjust it since I paid for the warranty. I've only used it one other time and I'm also having the flicker issue. My TV is one of the models that falls under the issue so hopefully I'll get three tubes replaced.
  6. *Carl*
    *Carl* Auditioning
    May 14, 2006
    Hi everyone, I'm new to the board and registered specifically because I have that same problem (red semi circular lines in my screen mainly visible when the screen is dark) .
    Michael I'm not sure if I get what you mean (sorry my first language is french, not english) the adjustement and calibration you're talking about , aren'T adjustement we can do ourself with the remote right cause I've tried everything and ended up beeing able to attenuate the lines a bit but not get rid of it. Is it an adjustment that needs to be done internally by a pro?
    It looks like this
    [​IMG]
  7. kumar
    kumar Stunt Coordinator
    Aug 9, 2002
    207
    I have had similar issues except for me it was blue lines.
    but as micahel said, it needs adjustment. I was on extended warranty(Iam still no) when my Sony had this issue.
    The guy replaced the blue and readjusted the levels and its working fine.
    Since I am still on warranty once in a while I open the bottom part of the TV and adjust the guns myself ;-)
  8. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    greetings
    find the red trimpot control on the screen trimpot black box under the front speaker panel and wood panel. Turn it down will remove the lines ... but you will have to retweak your grayscale as a result.
    It may also be a sign something will go one the set soon.
    Regards
  9. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    to add to what michael said, the trim pot knob is very sensitive, it may only take a touch of it to remove the lines.
  10. Edwin-S
    Edwin-S Lead Actor
    Aug 20, 2000
    6,873
    725
    9,110
    Don't you need specialized equipment to re-adjust grey scale?
