Depending on your model, look the the axis control, I believe you change it to 1 to eliminate the red push. Do this while generating a color bar image to ensure you have the correct setting selected.
Once you make the change, hit mute then enter to save the information.
Please be very careful while in the service mode, you can inadvertantly change the wrong setting and hose your set.
