Red push on PT47WX42
Discussion in 'Archived Threads 2001-2004' started by Howard Christian, Sep 24, 2002.
  1. Howard Christian
    May 19, 2001
    33
    Anybody fixed red push on this model and have the values?
    The one on www.panny.tv is for the WX49 model and don't seem to work on my WX42
  2. Howard Christian
    May 19, 2001
    33
    Also do anybody know the procedure to fix red push?
    Is there like a test picture or something like in VE?
  3. Manuel Parrado
    Manuel Parrado Stunt Coordinator
    Jan 7, 2001
    119
    I would also like to know.
  4. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
    The WX42/WX52's colour decoder is pretty darn accurate out of the box. Unless you know what you're doing, there's really no point to changing the default values.
  5. Ming Wang
    Ming Wang Agent
    Aug 13, 2002
    43
    I don't have red push on my 53WX42 either.
  6. Howard Christian
    May 19, 2001
    33
    Ming can you PLEASEEE post your color, BYG and RYA settings? really want to try out your settings
    I think mine really looked quite screwed
    and I can get it right!
  7. Ming Wang
    Ming Wang Agent
    Aug 13, 2002
    43
    Howard,
    my color is 1D, BYG 40, RYA 80, tint 80
  8. Howard Christian
    May 19, 2001
    33
    Is that your default settings or you did some adjustments?
  9. Howard Christian
    May 19, 2001
    33
    It's actually fairly close to what i have at default
    I have color 21, BYG 41, RYA 80 also
    something is just not right..gotta figure it out..
    Thanks Ming!
  10. Manuel Parrado
    Jan 7, 2001
    119
    Howard.
    Try to get a copy of AVIA it may help diagnose what's wrong with the TV.
    I also think my 53wx52 has some kind of problem. After calibrating with S&V HT Tune UP, I feel everything has a slight brownish/yellowish hue to it. Also, when the room is dark and a black screen comes up, it looks reddish instead of black
    I need to get AVIA myself and find out whether this is due to grayscale, color decoding, etc.
  11. Kevin Alexander
    Kevin Alexander Screenwriter
    Apr 17, 1999
    1,357
    I have the red push as well on my 53WX42.
  12. SeanWillis
    SeanWillis Agent
    Aug 31, 2002
    42
    What's your temperature setting? Warm will give that brownish/yellow hue to the picture. Putting it to normal will help.
    Cheers,
    Sean
  13. Howard Christian
    May 19, 2001
    33
    Sean,
    What are your settings for the color, BGY and RYA?
  14. SeanWillis
    SeanWillis Agent
    Aug 31, 2002
    42
    Sorry, I haven't accessed the service menu.
    Cheers,
    Sean
  15. Manuel Parrado
    Jan 7, 2001
    119
    Sean:
    Right now I have the color set to warm.
    I will set to normal and re-calibrate and see what happens.
    Thanks a lot.
  16. errol
    errol Stunt Coordinator
    Dec 29, 1999
    150
    Hi ya folks,
    Another options of course without having to go into the service menu is getting an attenuator. Cost is a few bucks and if doesn't work, you can return it to the store.
    Errol
  17. Manuel Parrado
    Jan 7, 2001
    119
    Errol:
    Can you elaborate a little on this?
    What does the attenuator do, where do you connect it and does it work for both progressive and interlaced?
    Thanks.
  18. errol
    Dec 29, 1999
    150
    Hi Manuel,
    It's a device that installs inline with the signal that has the problem. In this instance and most of the time, it is the red component. So you get this device, plug in the device component red out to it, then it to the red component in of your display. Simple. [​IMG]
    Pls go here for more info.
    Errol
  19. Manuel Parrado
    Jan 7, 2001
    119
    Thank you for that information.
    Sounds like a good trick.
