Red Hat Linux 9.0
Discussion in 'Computers' started by Glenn, Aug 11, 2003.
  1. Glenn
    Glenn Stunt Coordinator
    Oct 26, 1998
    229
  2. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
  3. JamesHl
    JamesHl Supporting Actor
    May 8, 2003
    813
    You can set red hat to install apache. I would recommend getting a book on apache if you're serious about using the computer as a web server. Else you can use the readme to direct you to edit enough of the config files to get you going.
  4. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    You might find just the RedHat documentation to be sufficient, depending on how much previous knowledge you have. http://www.redhat.com/docs
    I'm running a web and email server on RedHat 9 (and another on RedHat 8). I've been very happy with it.
  5. MikeAlletto
    MikeAlletto Cinematographer
    Mar 11, 2000
    2,369
    Google is your friend. As is google groups.
  6. Joe Hsu
    Joe Hsu Supporting Actor
    Jul 2, 2001
    812
    I second the notion to go to linuxnewbie, as they have lots of valuable information...I'm just in the midst of installing and running the old family box with apache/php/mysql so I don't have to keep testing on a remote webhost server...much faster to have the server upstairs. [​IMG]
  7. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    Red Hat isn't necessarily the best server box either. There are cleaner, safer and more hardened linux distributions out there to do what you want to do.
    Red Hat is great as a desktop, though. Very user friendly (for Linux).
  8. JamesHl
    May 8, 2003
    813
    As long as you only install what you need, it is pretty secure. If it's going to be exposed to the internet, you should of course run Bastille or something like that and either setup a good iptables firewall or have it running behind a well configured hardware firewall. You'll still be vulnerable just because you're running apache, but it's the best you can do and still be exposed to the internet.
