Recording streaming audio
Discussion in 'Computers' started by Chris Bardon, Feb 21, 2006.
  1. Chris Bardon
    Chris Bardon Cinematographer
    Jul 4, 2000
    2,059
    One of the local radio stations runs a great series (The Ongoing History of New Music with Alan Cross for those that are interestedhttp://www.edge.ca/station/ongoing_h...ll=6743&pge=1#) and I've often thought that it'd be great to record for commuting. They just started putting up archived shows, but the problem is that they're all streaming audio. I'd like to find a decent (free if possible) stream recorder to capture these for the mp3 player. Ideally, I'd like to be able to schedule recordings of a URL.
    Looks like there's a whole pile of applications out there-anyone have any recommendations?
  2. Jason Harbaugh
    Jason Harbaugh Cinematographer
    Jul 30, 2001
    2,968
    I've used Station Ripper a lot and it works great. Seperates each song, creates a database so it won't record the same song twice, allows you to purchase the music you just heard, gets album art. I've only used it with Shoutcast, but apparently it works with other stations. Not all are compatible, but the software is free so no harm in trying.
  3. Joseph S
    Joseph S Cinematographer
    Dec 23, 1999
    2,862
    If you have access to a Mac, Audio Hijack and Audio Hijack Pro will do all this and more.
  4. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    Check out Total Recorder. It has a scheduled recording feature and can be scheduled to open your streaming player to a certain URL at a specific time, then record the stream for the amount of time you specify.
