Recording HDTV - DVD Recorder?
Discussion in 'Archived Threads 2001-2004' started by Greg_Ritchie, Oct 30, 2002.
  1. Greg_Ritchie
    Greg_Ritchie Stunt Coordinator
    Aug 10, 2002
    54
    Are any of the current DVD Recorders capable of capturing HDTV images? I assume the Panasonic can't tape HD since it doesn't have a component input, does the Phillips down convert the HD images to DVD resolution. The only use I would have for a recorder is to tape HD or Digital Cable shows that I miss. I know they would not look like HD but would they look much better than SVHS? My non HD cable channels don't really look good enough for me to justify buying a DVD recorder.
    Greg
  2. Joe Szott
    Joe Szott Screenwriter
    Feb 22, 2002
    1,962
    Nope
  3. Frank_S
    Frank_S Supporting Actor
    Oct 28, 1999
    565
  4. Gary Thomas
    Gary Thomas Second Unit
    Jan 17, 1999
    389
    I'm probably wrong, but I thought that the d-vcr's can make HD tapes of OTA HD material through a firewire connection. I believe Samsung has an OTA receiver w/ firewire that can connect to a Panasonic D-VCR.
  5. Steve Phillips
    Steve Phillips Screenwriter
    Jan 18, 2002
    1,526
    Current DVD recorders can only record in DVD quality. Right now, if you want to record in HD, you have to use D-VHS.
    Can DVD recorders produce an image better than S-VHS? Yes, if set at the 1 or 2 hour speeds. Some would say the 2 hour speed is similar to S-VHS. I think it is a hair better than S-VHS SP.
  6. Greg_Ritchie
    Aug 10, 2002
    54
    Can I record my HD signal on the DVD Recorder at DVD quality? I know the panasonic has no component input so I don't thinks it's possible, the Phillips I know has component in. The problem is that my other digital cable channels aren't DVD quality so unless I can record the HD channels I'm probably better off with SVHS.
    Greg
