Recommended KV-27V42 tweaks
Discussion in 'Archived Threads 2001-2004' started by chris beck, Feb 27, 2002.
  1. chris beck
    chris beck Auditioning
    Feb 25, 2002
    9
    I've done the following tweaks with positive results:
    AXPL to 1 - helps with red push
    Y-DC to 0 - improves black levels
    I've read the AWH and Keohi sites but I'm not sure which tweaks apply specifically to this model versus Wega/XBR models; for instance, SHPF only toggles between 0 and 1 on my set - there is no "3." I have the Video Essentials DVD - are any other tweaks recommended?
  2. chris beck
    Feb 25, 2002
    9
    Update: Now I've changed the value of DCOL to a setting that makes whites look less blue. So far, so good!
  3. chris beck
    Feb 25, 2002
    9
    Now I've changed SHPF from 0 to 1 - it improves apparent focus in the Video Essentials sharpness pattern (14/3) without exaggerating edge detail.
  4. Adil M
    Adil M Supporting Actor
    Nov 21, 2001
    922
    Keep going Chris. I will follow after step by step. Yes, I am using you.
