Recommended DVD player $200 and under.
Discussion in 'Archived Threads 2001-2004' started by Tray, Sep 12, 2002.
  1. Tray
    Tray Stunt Coordinator
    Sep 2, 2002
    56
    10
    I am in the process of ordering my HT system. So far I have:
    JBL 2 series for main and front speakers with JBL N series for rear surround. HK AVR-520 receiver with a Toshiba Cinema series 36" TV (36x81).
    What DVD player can you recommend that will also play CD's as well as MP3 cd's?
    I would like to keep this under $200.
    Thanks!
  2. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
  3. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Tray, Pablo made some very good suggestions. You might also consider the Toshiba SD-4800. Best Buy has it for under $200. Like the 'RP82, the '4800 also plays DVD-Audio discs. Also consider the Pioneer DV-353K for $150. Pioneer makes solid budget players. See www.crutchfield.com for more on the '353K.
  4. Manny_S
    Manny_S Stunt Coordinator
    Sep 4, 2002
    54
    I bought my RP-82 for $191 at Brandsmart, a local warehouse style electronics & appliance store. It's an excellent DVD player, as long as you can tolerate the chrome/silver exterior, which is the only color it's available in. If you don't care about MP3 playback, you can go with the less expensive RP-62. It's exactly the same player except for the lack of this one feature.
  5. Tray
    Sep 2, 2002
    56
    10
    Thanks for the suggestions!
  6. MikeSRC
    MikeSRC Second Unit
    Jul 19, 2002
    369
  7. Tray
    Sep 2, 2002
    56
    10
    I bought the Panasonic RP-82 from JandR for 221 shipped.
    Thanks for the suggestions [​IMG]
  8. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
  9. Brian O
    Brian O Second Unit
    Apr 27, 1999
    284
    Is the RP72 the same as the RP82 except with the changer?
  10. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Brian,
    The 'CP72 and 'RP82 are very similar. This was discussed here recently. A search should prove useful.
    Mike,
    You could very well have had a defective 'RP62. Given that the 'RP62 is designed to play DVD-Rs, I wouldn't assume that the problems you experienced are inherent to the model. In any event, you're better off as you have DVD-Audio now. [​IMG]
  11. Manny_S
    Sep 4, 2002
    54
    Doesn't the RP-91 use the "Genesis" Mpeg decoder? I initially thought the RP91 and RP82 both used the Sage/Faroujda chip, but then I read somewhere that this was not the fact. Now, I did also read that the RP62 also uses the Faroujda.
  12. MikeSRC
    MikeSRC Second Unit
    Jul 19, 2002
    369
    You're confusing deinterlacing chips with MPEG decoders. The RP-91 uses the older model Genesis deinterlacer. The RP-56, 62, 82 and CP-72 all use the Sage/Faroudja deinterlacing chip. They all use Panasonic MPEG decoders, just different ones.
  13. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
