Clay Kilpatrick
- Sep 18, 1999
With school starting next week, I plan do do my commuting by bicycle, and I am going to need a way to lock my bike up. Does anyone have any good suggestions of a lock to get? I guess with quick release tires, you are supposed use something that will lock the tires as well as the frame, which would eliminate those D shaped locks. Cable locks look like they would be really easy to cut though.
The manual also mentioned that with quick release seats, you should remove the seat and take it with you, so it won't get stolen as well. Is this really a problem? I can't imagine having to take the seat off all the time, and spending the time trying to get it to the right height again. I thought that if it really should be done, I would see if I could replace the quick release with something a little harder to remove.
Anyhow, thanks for any suggestions.
Clay
Clay
