Recommendations Sought for A/B Capable Receiver
Discussion in 'Archived Threads 2001-2004' started by Neil White, Mar 24, 2002.
  1. Neil White
    Neil White Supporting Actor
    Jan 8, 1999
    551
    I'm looking for a receiver that will intially power deck speakers (JBL N24AW) for music (stereo). The receiver will actually sit in the family room rack. At the moment, my family room has HDTV/DVD/VCR/SAT but no surround. I may never put surround in the family room but in case I change my mind, I want the receiver to be able to switch between A and B speakers and preferably, have an option to play through both at the same time as well. If I ever go surround on this receiver, DTS would be preferable but not a must and 5.1 is adequate.
    I really don't want to spend much as this hobby of mine is getting out of hand.
    Any good ideas please.
  2. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Based on my experience:
    JVC RX-8000VBK: Will not play through both "A" and "B" at the same time.
    Denon 1802: Will play through both "A" and "B" at the same time.
    Marantz 5200: No "B" speaker connectors, so this is not an option.
  3. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    The yamaha htr-5440/rx-v420 features a/b switching for the mains and allows you to run them both at the same time. It also has DD 5.1, DTS, and 5 channel stereo. Only problem is that your JBLs aren't very efficient so running both A and B speakers may be too much for the Yamaha's 65 wpc amp. You can find the htr-5440/rx-v420 for a little less than $300.
  4. MikeKaz
    MikeKaz Stunt Coordinator
    Aug 6, 2001
    152
    well not the 5200, but the marantz SR-7200 will play through A and B at the same time. the 7200 also has a multi room output feature where if you got a small little crappy amp for the deck speakers, you can have the family room playing a different source than the deck. e.g. if you were watching dumb and dumber on dvd you could have the latest N'sync album blasting on the deck all through your one receiver and at the same time.
  5. Neil White
    Jan 8, 1999
    551
    Thanks for the help folks. I'll research your suggestions.
    N
  6. MichaelJ
    MichaelJ Agent
    Feb 1, 2001
    33
    The Denon 3802 has seven seperate amps and allows 5.1 in one room while giving you two channels for a second room .Check it out
