JustinCam
- May 5, 2003
Hello All,
I’ll start off by saying I’m new to HT and appreciate any input, although this is my first post this forum has already helped me tremdenously.
I’m currently in the process of converting a section of my basement (140x250”) into a dedicated HT. One of the problems is the low ceiling height around the parameter of the room 77” this is to conceal some duct work and was done by the pervious owner along w/ the drywall on the ceiling.
The projector I’m using is an InFocus X1.
For my sreen I plan on making a DIY unit w/ blackout cloth, I am new to HT, but also a new homeowner so I’m on a budget.
My question as far as screen size is do I go w/ 4:3 or 16:9. Originally I was set on 16:9 but then I got thinking, I also plan on using it for xbox and ocasional TV viewing, so maybe 4:3 is the way to go?
Things I also need to consider is the X1’s realativly low light output especially in movie mode, so I read that I should keep the screen size between 80-90” diagonal, would you agree with this..?
If that’s the case and the blackout comes in a maximum 54” width, so in 4:3 the screen would be 54x72”.? Is this a good size for my room/equipment..?
Wow, that’s a fairly long post again thanks in advance for any and all help..!
Jusitn
Jusitn
