nighthawk15
- Apr 25, 2008
- William
Well first I would like to introduce myself. My name is William, I am no stranger to electronics but honestly know nearly nothing about home theater audio equipment and would like to learn more because my parents are looking to get a new system! It is to be used with a 47" LCD TV in a fairly average but good size living room. If you need exact dimensions I can get them for you. The parameters for the system itself are:
Definitely a bit more tame than most here would probably be after, and honestly I would probably want to get something with a bit more balls as well (I love it when something blows up and the room shakes
), but that's the parameters I was able to gather with the conversation I had with my mom. To quote her "I don't care if I feel like I'm going through the tunnel with the train". I would also like to know your opinions on preconfigured/canned systems and if there are any you would recommend, or if a custom setup is the best way to go? Thank you very much in advance for any help!
P.S. I am not so sure I put this in the write forum, but everywhere else appears to be specific to one type of audio or video component. If it this in the wrong forum I apologize.
- $500 budget. Can be a bit more though if it will make a big difference.
- The subwoofer needs to be strong enough to provide enough bass to give the sound some kick so it doesn't seem flat, but at the same time my mom doesn't want it booming and rattling outside of the house. I imagine that means a very small sub could do the job, but as said above I have little knowledge of the specifics.
- very similar deal with the speakers as the sub. Good sound with nice highs and lows, but they don't really need to be able to blow the roof off. Just strong enough to get some nice volume.
- I am guessing an amp/receiver will be needed as well, so whatever you guys think is a good choice.
