Recommendations for Component Cables
Discussion in 'Archived Threads 2001-2004' started by Neil White, Feb 10, 2002.
  1. Neil White
    Neil White Supporting Actor
    Jan 8, 1999
    551
    I would like to get some recommendations/opinions for component cables. I'm looking for 1.5 or 2.0 meter lengths to connect between a non-progressive DVD player and a digital TV.
    I like quality but dislike very highly priced cables. I'm purposely not posting my price range to see what y'all have to say.
    N
  2. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
    AR Pro Series
  3. Mark Rich
    Mark Rich Second Unit
    Oct 24, 2001
    457
    KustomKables.com
    Bettercables.com
    Rhinocables.com
    Wickedcables.com
    etc...
  4. Todd K
    Todd K Second Unit
    Oct 21, 2001
    477
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Neil: I have often recommended AR/Radio Shack cables for modest systems.
    But yours does not qualify.
    Does your HDTV do line-doubling? This means it takes the analog signal, digitizes it, does all kinds of stuff to it to make it look better? I bet it does.
    You really want to hit the custom sites and get production-studio grade coax and connectors. Because of the processing involved in your system, the small change due to the cable can have visible results.
  6. Neil White
    Jan 8, 1999
    551
    Thank you all for the advice. I will check those sites out.
    Bob, I've ordered the Sony KV-32HS20. It has the line doubling. Sounds like I need to consider the higher grades as you suggest.
    Thanks again....
    N
  7. Bob McElfresh
    May 22, 1999
    5,182
    Neil: WickedCables will sell you a 2 meter (6 foot) set of component cables made with Canare Plugs & connectors for about $70. IMHO this is as good/better than the Monster Video 3 set that sells for about $280.
    Or, I can direct you to a web site that tells you how to build your own. (But the tools will set you back about $100-$200 so it's an investment in the future) [​IMG]
  8. Ed O
    Ed O Agent
    Sep 25, 2000
    36
    How are the RS cables with these product numbers:
    15-1508C Gold plated RCA cable (red, white yellow color coding)($15 for 6ft)
    15-1563 Gold plated Component video cables (red, green blue color coding)($50 for 6ft)
    They appear to be the same except for price and color coding. Opinions or experience with these?
  9. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
  10. Mark Rich
    Oct 24, 2001
    457
    Yes, Wickedcables makes a nice product. Think i would go with an RG6 cable though. Maybe KustomKables ?
  11. Neil White
    Jan 8, 1999
    551
    Thank you all again for the advice.
    N
