Check parts express.com. They'll lead you my son. Ask for the catalog, and shop early and often. Now what did I need again?
They have a stretchable cable covering which (sorry, I don't have the part number, but I don't work there either) so good luck. You might try the velcro cable binders too, because they are easily re-configurable, and do the job fine. Good luck.
The snakeskin looks better than the split loom, but that's just my opinion, so take it for what it's worth. What would you do with 40 subscriptions to Vibe anyways?
