Recommendations for a scanner under $200
Discussion in 'Archived Threads 2001-2004' started by Kevin_Graham, Apr 15, 2002.
  1. Kevin_Graham
    Kevin_Graham Stunt Coordinator
    Mar 1, 2001
    131
    I want to purchase a general purpose scanner with the best resolution possible for under $200. I do not need the ability to scan slides or negatives. I've been looking at the Canon and Microtek scanners and reading reviews about them but it's difficult to make a decision without seeing an actual copy or scan. Your recommendations would be appreciated!
  2. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Do you already have a good printer? If not then I can
    highly recomend the Lexmark X73 and Lexmark X83 Printer,Scanner,Fax,Copier combos.
    You can get the 73 for $140.00 ish or the 83 for $190.00 ish.
    Both do the same resolutions (the 83 prints a little faster)
    The 73 will scan up to 2400 DPI (9600 Software) and will
    print at a true 2400x2400 DPI (It's amazine!) Dare I say it
    is professional quality! With a cheap price tag ta boot.
  3. Kevin_Graham
    Mar 1, 2001
    131
    Actually I have a fantastic printer. The Canon 820 prints photos so beautifully they look like they were professionally processed!
  4. CarlDJr
    CarlDJr Stunt Coordinator
    Dec 14, 2001
    54
    CNET rates the Epson Perfection 1650 Photo as an editor's choice,
    http://computers.cnet.com/hardware/0-1073.html?tag=dir
    You can buy the Perfection 1650 (same model without the photo scanner) for well less than your $200. And there is a $30.00 rebate until the end of April.
    Good site is NewEgg where it is $166 plus $13 shipping. They also have the link to the rebate.
    PCWorld also highly rates the Perfection 1650.
    [​IMG]
  5. KyleS
    KyleS Screenwriter
    Jul 24, 2000
    1,232
    Kevin,
    Check your Mail
