Recommendations for 7 Channel Amp
Discussion in 'Archived Threads 2001-2004' started by JohnCro, Feb 5, 2003.
  1. JohnCro
    JohnCro Extra
    Jan 21, 2003
    15
    I would appreciate recommendations for a seven channel Balanced amplifier in the $1,500 - $2,2500 range. It will be powering a Sunfire Theater Grand III processor and Martin Logan Speakers.
  2. Mike_Gr
    Mike_Gr Stunt Coordinator
    Jan 14, 2003
    176
    Marantz SR9200
  3. Parker Clack
    Jun 30, 1997
    12,216
    59
    9,110
    Kansas City, MO
    Parker
    John:
    I can recommend the Outlaw 770 without any problems at all. It is 200 watts RMS x 7, weighs in at 90 lbs and makes extensive use of massive heat sinks for cooling instead of fans. Each output module has 10 discrete output devices, 22,000+ uF of total filter capacitance. THD is less than 0.05% at rated output. So this is a really clean amp. It is priced at $1,799.
    Parker
  4. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    There are only a few 200/7 amps out there. From what I recall there is the B&K 200.7, the Sherbourn 200/7 and the Outlaw 770. If it were me I would have chosen the B&K amp as I am familiar with its warm sound and good built quality. Also ATI amps (same OEM for Outlaw amps) IMO are slightly bright sounding. I have no experience with Sherbourn but from what I have heard they are quite neutral sounding. So there you have, a warm sounding amp (B&K) a neutral amp (Sherbourn) and a forward sounding amp (Outlaw). Based on your speaker timbre and your personal listening preference you can choose either of these. I have personally listened to ML speakers hooked to B&K amps and I think the combo sounds very transparent and airy. In any case I think you would be happy with any one of these.
    Best of luck.
  5. ChrisHeflen
    ChrisHeflen Supporting Actor
    Sep 9, 2002
    912
  6. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
    I called Sunfire last Friday and asked if they have a 7 channel amplifier. I was told that the Sunfire Cinema 7 and Sunfire Cinema 7 Signature will be available in March.
    I didn't ask about prices.
  7. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    JC- If you listen to a lot of music, I would recommend getting a separate 2 channel amp and a 5 channel amp. I did this a little while ago, and I really like the results (plus I can kid myself that it's environmentally better in terms of not wasting power for channels that aren't needed). All of the above mentioned manufacturers do 2 and 5 channel versions. The B&K's are really nice, Aragon too, but a little pricey. Might be able to find B&K's "last year's models", the Ref 2220 and 7250 cheap(er).
