Recommendations for $600 (per pair) front speakers
Discussion in 'Speakers & Subwoofers' started by Shane Morales, Jul 16, 2003.
  1. Shane Morales
    Shane Morales Second Unit
    Jul 9, 2003
    433
    [nevermind, just noticed there's another post almost exactly like mine]
    Primarily for music. I want something with a warm sound.
    Also used for movies, but with just the two speakers (for now)
    Nothing fancy - these are for my parents; they're not much into electronics.
    Preferably with cherry veneer.
    Will be paired with a Denon-1803 and Pioneer Elite 5-Disc DVD Changer
    Thanks.
  2. Kevin Day
    Kevin Day Auditioning
    Jan 13, 2002
    7
    Just in case anyone else comes in, I'll post a link to my thread: Go here
  3. NickC
    NickC Second Unit
    Jan 19, 2000
    290
    B&W 602 Series 3....
  4. sheldon M.
    sheldon M. Stunt Coordinator
    Feb 14, 2003
    68
    Check these out-http://www.goodsound.com/equipment/athena_asf2.htm
    Haven't heard them myself but the reviews are great and they are exactly $600
  5. Jeffrey_B
    Jeffrey_B Agent
    Sep 24, 2002
    36
    Pair of Polk LSi9's. They list for over $1000 but can be had on-line for about $600 a pair. Comes in ebony or cherry. Sounds warm, great bass from a small book shelf size speaker. Chack out Polk's web site for more info. I have the 9's, C, and FX's and will be buying the 15's (floor standers). JEFF
  6. Arthur Vino
    Arthur Vino Stunt Coordinator
    Mar 13, 2003
    208
    Energy C7s?
  7. Steve_D
    Steve_D Second Unit
    Nov 28, 1999
    299
  8. Doug Brewster
    Doug Brewster Second Unit
    Jul 22, 2002
    325
  9. JauCheeze
    JauCheeze Stunt Coordinator
    Sep 24, 2002
    87
    I have the polk lsi 9's. You will need a lot of power to drive these speakers. I'm running mine w/ a sr600, and it is simply not enough power for the Lsi's. Also the Lsi's are rated at 4ohms.
  10. Mike_Gr
    Mike_Gr Stunt Coordinator
    Jan 14, 2003
    176
    Wharfedale Evo's. Give them a listen. They are warm (not too warm) and an excellent value.
    If you can find a dealer near you, they are worth the drive to check them out.
    They do come in a real wood veneer similar to cherry (rosewood).
  11. Lee-M
    Lee-M Stunt Coordinator
    Jan 2, 2003
    162
    Used Klipsch. You can get a pair of Heresy's or Fortes on ebay for between $600 and $750, and will be hard pressed to find anything for that price that sounds better.
  12. Mark Dickerson
    Mark Dickerson Stunt Coordinator
    May 10, 2003
    128
    Given the following info:
    1. They are for your parents;
    2. They are primarily for music;
    3. They are connected to a Denon 1803 (amp is a bit dry);
    4. You would prefer a cherry veneer finish; and,
    5. You have a budget of $600 or less;
    I would recommend you go to Audio Advisor (www.audioadvisor.com) and get some of the Mirage speakers they are closing out. The FRx-3 is being sold for $199/pair (normally $350/pr.) and it has a very nice liquid sound that really comes alive when playing music and also will balance out your Denon receiver (won't be quite so clinical sounding). And it comes in a a nice Cherry finish your parents will like.
  13. paulBAW
    paulBAW Stunt Coordinator
    Apr 18, 2003
    57
    Polk Audio LSi9's are by far the best speaker listed thus far, only I don't think a Denon could run the 4ohm load...There have been threads about Denon's having troubles with 4ohm loads. And the LSi's are very hungry. They weight in at 32lbs a speaker. But that Vifo tweeter...ewwwww ahhhhh
  14. Jeffrey_B
    Jeffrey_B Agent
    Sep 24, 2002
    36
    I have a Sony ES30 receiver running my LSi9, LSiC, and LSiFX with no problems. JEFF
