JohnGoggan
- Aug 14, 2002
I used to have a Sony HT-DDW740 Home-Theater-in-a-box setup that I bought for $300 from WalMart (mainly because I had Sony points on my credit card and was able to get it for free). I liked it -- sounded fine after calibrating -- no real complaints from me for what I paid.
Recently, however, I bought a new Hitachi 57" widescreen RPTV and I added some gaming consoles to my setup. I then needed a receiver with multiple optical inputs -- so I upgraded to the Panasonic SA-HE100K receiver.
I've been using my HTIB Sony speakers with it for a while, but I think I want to move to something better. Plus, I'm going to sell the Sony HITB setup -- and it'll go for more if I put it all back as the package that it originally was.
So, that leaves me with about $200 -- and looking for a new set of speakers and a subwoofer. My living room is about 18' wide and 13' deep (leaving me about 8' from the TV after you figre for the TV and couch).
Any/all suggestions are appreciated. I'll consider used equipment also if anyone has some decent stuff.
Also, the SA-HE100K is a DTS-ES compatible receiver. Should I therefore worry about adding a rear center speaker now also? My couch is right against the back wall -- so I'm not really sure how I would fit it in. But, I can see moving things around later -- so if I buy a set of speakers now, maybe I should get the rear center just to have for when I rearrange things?
Thanks for your time/thoughts/suggestions!
- John...
- John...
