PatrickS
- Jul 31, 2002
Sealed or custom Mini-Thunder to be used 50/50 for music and HT?
I currently have the 2 cu. ft. Custom Mini-Thunder with external measurements of 17" x 17" x 20" and is down-firing (the standard Mini-Thunder is 16" squared) which I've used with the original AV12 (sold with another cabinet), and the Rythnik Servo Amp/Driver (not enough punch for HT, and kept bottoming out). the Mini-Thunder really puts out with the AV12, but I decided to go with the better warranty of the Titanic.
NOW, after doing some more research, I've read that many people recommend the 12" MKIII with a "sealed" 2 cu. ft. enclosure. Which of course would be much better for music, I just don't know if it will be enough for movies. The Mini-Thunder actually does fairly well with music in my room, and I really don't want to deal with the hastle of selling it, unless it will be a marked improvement.
To give a little background:
The Mini-Thunder has dual 12" 970 gram PR's from Stryke audio and the cabinet is tuned to 20 Hz. Besides a substatial dip (11 dB) at 28 Hz, freq. is very flat between 17.5 Hz and 80 Hz within 4-6 dB. I had Parts Express run bassbox with the 12" MKII in the Min-Thunder, and they said it was pretty flat from 100Hz down to 18Hz (within 8 dB).
Because of room limitations the sub sits right behind the center of my couch (listening position)against the wall. The couch is out 2 ft. from the back wall in a room that has 3 walls (15 ft. x 12" by vaulted ceiling), with the fourth wall not being there and opening into family/kitchen/dining room. The total floor space of the combined rooms is about 25 ft. x 20 ft. with the vaulted ceiling going from 10 ft. to 13 ft. in the center. A VERY bad room, but with acoustical treatment, having the sub right behind the listening position, and mains that go down to 30 Hz, I have it sounding pretty good.
But as usual I want better if I can, with what I have. That being the Titanic 12" MKIII and the rythmik amp. I already have the Mini-Thunder as I've explained, but given my situation (room constraints and 50/50 listening preferences)would anyone recommend going to a downfiring 2 cu. ft. SEALED enclosure? I definately have to stay with the 2 cu. ft. size regardless, and I really prefer the downfiring cofiguration.
Any input would be greatly appreciated!
Thanks and Best Regards,
Patrick
Patrick
