Recommend wall mount racks/shelves for your components?
Discussion in 'Home Theater Projects' started by Jason_B, Feb 28, 2004.
  1. Jason_B
    Jason_B Auditioning
    Feb 28, 2004
    5
    Hunting around I have found the following:
    A bit ugly (gigantic pole), doesn't specify if it's 44lbs TOTAL or per shelf.
    http://www.racksandstands.com/asp/sh...M0033&catid=51
    Seems like it would be virually invisible. Since it supports 100lbs, I could stack two/three items on it.
    http://www.racksandstands.com/asp/sh...E0132&catid=51
    The MAVb/MAVw units. Only hold 45lbs, so a reciever will eat that up. Would need two or three then...
    https://www.sanus.com/cgi-bin/web_st...d=3562460_5335
    Something "like" this, but maybe just two shelves. This one cannot work at all though, 25lbs per shelf...
    http://www.racksandstands.com/asp/sh...VP0032&catid=4
    ANY other solutions you are familiar with? I think a thick/beveled piece of glass could look nice, but no clue on how thick it would have to be... or if this is even an affordable route to explore. Nice looking solution that hangs from the ceiling within this nook area?
    Decor: contemporary-ish/modern-ish.
    Location: above big screen. Cannot go below, because viewing angle would then require rasing the couch/chairs, which is not an option.
    Available space above TV: H 3ft, W 5ft , D 2ft
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,130
    40
    6,610
    Katy, TX
    Wayne
    Jason, all of the links bounced.
  3. Jason_B
    Jason_B Auditioning
    Feb 28, 2004
    5
  4. Jason_B
    Jason_B Auditioning
    Feb 28, 2004
    5
  5. George Balzer
    George Balzer Auditioning
    Dec 3, 2002
    10
    Jason, do you have any pictures or links of your theatre to give us a better idea of the application?
  6. Jason_B
    Jason_B Auditioning
    Feb 28, 2004
    5
    Nope, but that picture above of the plateau unit perfectly illustrates my situation. I have a nook area where the big screen lives, and I want to place equipment above it. My bigscreen has a very small top, so I cannot even consider stacking equipment there.
  7. Jason_B
    Jason_B Auditioning
    Feb 28, 2004
    5
