Recommend me a sub to go with the SCH K05B50
Discussion in 'Archived Threads 2001-2004' started by MikePenn, Jan 24, 2003.
  1. MikePenn
    MikePenn Auditioning
    Dec 9, 2002
    13
    Since I know a lot of people here seem to have built the K05B50 (which I am really considering building), I was wondering if anyone had a recommendation for a good sub to go with them. The sub could be DIY or bought whole, just as long as it is inexpensive (ie ~$100-150). I was thinking about the PE DLS 10".... any thoughts??
    Because I plan to use the speakers in a stereo setup, I was really tempted to just build the K05B11. However, it seems like the K05B50's are generally considered to be better speakers, and are magnetically shielded which is a plus.
    Mike
  2. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Mike,
    With that budget I'd definitely go with the Dayton DLS 10" sub. It's a great performer for $100 and several people have compared and preferred it to the Sony sub that has been raved about over in the hardware section.
  3. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    i use the DLS 10" sub with my k05b50s and it works great. i was using a yamaha yst-sw105 before the DLS and it just didnt have the depth and accuracy of the DLS...the much better build quality on the DLS probably contributes a lot to this
    it's hooked up off the preouts on my receiver if you were wondering...
