Recommend me a projector please
Discussion in 'Displays' started by jonnyMa, Mar 6, 2006.
  1. jonnyMa
    jonnyMa Agent
    Feb 20, 2006
    28
    Could someone recommend me a good projector for under $2400? I assume the panny ae900 will be the choice of most but are there any other options I should be looking at or anything I should know about the ae900 before I take the plunge? Thanks.
  2. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    There are a quite few good ones under $2400. The Sanyo Z4 is another one(LCD). Are you only considering LCD projectors? And I assume you want a HD projector?
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    There is a Display Devices section that is appropriate for this Q.
  4. jonnyMa
    jonnyMa Agent
    Feb 20, 2006
    28
    My apologies chris, I only realised I posted in the wrong forum when I checked for replies:b
  5. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Jonny: Please do not repost the same question twice. In this case, I had moved your earlier thread to Display Devices. Only later do I discover you had reposted. Always report the misplaced post, and the staff will move it to the appropriate area.
