Recommend fronts to match Take 5's? (1 Viewer)
Rod Martin
Rod
When I got into HT about 7 years ago, I went with the Energy Take 5 speakers (center, sub and rear surrounds). To save a bit of money, I stuck with my front L and R speakers (can't remember what they are now..but they were my Dad's and are massive and heavy - I refoamed them 7 years ago too).
Anyway. The reason I don't know what brand they are is because I am out of state in a new apt and new job. I brought my inFocus with me and will be buying a new A/V receiver (maybe a Yamaha RX-V2500). On my next round trip, I plan to bring back my Energy's, but can't (just no room in the car, man!) bring the fronts. So, I plan on buying new fronts and wanted to know if anyone could reccommend ones that would best match acoustically with my Take 5's. I'm not even sure if this is a question that can be answered, but I thought I'd give it a go.
Thanks in advance!
Paul_Dunlop
I would either
(a) go online and search for used Take 5 Energy Speakers to exactly match your existing speakers
(b) stick with Energy and buy some of the new Take speakers or new C Series speakers from them
this would be a nice upgrade and should match OK
http://www.energy-speakers.com/v2/
Rod Martin
Rod
So, for the Energy C Series, would you advise the C-100 or 200 being the best match for the Take 5 rears and center?
Paul_Dunlop
Generally timbre matching is about the tweeters, so they both should match the same to the Take 5
Another option is to buy 3 C-100's for the fronts and center
Then move your Take center to be a rear center
Since you will be getting a new receiver anyway, it will likely be a 6.1 or 7.1
Then your front stage matches perfectly, and you have a good migration path to a full 6.1 system
Good Luck with this
Cuseman628
