Recommend an internal DVD drive (for desktop)?
Discussion in 'Computers' started by Darren H, Feb 15, 2005.
  1. Darren H
    Darren H Second Unit
    May 10, 2000
    447
    The DVD drive in my desktop has been giving me fits for a couple months now, and I think it's finally crapped out. Any suggestions for a relatively inexpensive DVD+/-RW drive?
    - Windows XP Home
    - Pentium 4 - 2.8GHz
    - 512 MB RAM
    Darren
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    Don't think you can go all that wrong with the current offerings by Benq or NEC DVD burner drives. They go for around $55-$65. If you need burning software, you may need to go for the retail version of the drives. I've good luck with using Nero 6.x.
  3. Chris
    Chris Lead Actor
    Jul 4, 1997
    6,788
    The NEC is an excellent choice, especially for set top compatibility in writes. Does a very good job.
  4. Ken Chui
    Ken Chui Supporting Actor
    Jun 20, 2003
    976
    Deciding on a DVD burner is tricky because very few drives handle most media* reliably (* when you take into consideration the various DVD R/RW disc formats, as well as CD-Rs).
    Not sure what your budget is, but I would recommend putting together a list of models that appeal to you and checking their reviews on sites such as CD Freaks and/or CDRLabs. While most of the recent drives from NEC and Plextor have fairly solid track records, little things such as firmware revisions can affect their overall performance. Never buy by brand, but by model.
  5. Darren H
    May 10, 2000
    447
    Thanks for the help, guys. I'm thinking about ordering an NEC ND-3520A, and the best price I've found is $64.50 from ZipZoomFly.com. Any other advice (about drives or etailers) before I make the plunge?
    Thanks.
  6. Ken Chui
    Jun 20, 2003
    976
    Darren:
    Excellent choice from a reputable e-tailer. Do you know if a firmware upgrade has been released to support DVD-R double layer writing? One site reviewed this unit on January 25, but DVD-R double layer writing wasn't supported when the article was written.
    If you're looking at other drives with similar specs to the NEC, you may want to check the Plextor PX-716A and the Toshiba SD-R5372 (the NEC is the best bargain of the three).
  7. DaveNel
    DaveNel Second Unit
    Oct 13, 2004
    447
    I have a Micro Advantage Burner, And I have yet to see a problem This is a DVD/RW + and - Dual burner...
