Recommend a car cover...
Discussion in 'After Hours Lounge (Off Topic)' started by Jay H, Sep 26, 2005.
  1. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    Can anybody recommend a decent car cover for outside use? I'm looking to store a convertible outside and wouldn't mind some protection from the elements, snow, so something that is waterproof is good.
    I've heard on a board about "California Car cover", would this work in NJ? [​IMG] Just kidding, but are they any good?
    www.calcarcover.com
    Jay
  2. gene c
    gene c Producer
    Aug 5, 2003
    5,850
    51
    9,110
    Bay area, Ca
    Gene
    Believe it or not, J C Whitney actually sells an almost water proof cover for only $65-$80 depending on size. The part number is WH260_ _ _. The last three numbers are for the size ordered. I use it on my Fiat 124 conv that's parked under a carport and when it rains (the wind blows the rain under the carport) there's not a drop on it. I also have a '72 450SL that's under a much more expensive Noah Evolution 4 cover (admittedly better "ding" protection) and there's always a little water on the Merc'. BTW, I also suggest buying a cheap $20 cover to put on top of the better cover. The cheap one will keep bird droppings and who knows what else off the better one.
  3. John Spencer
    John Spencer Supporting Actor
    Mar 2, 2000
    857
    A garage.
    Sorry. Had to be said. [​IMG]
