recommend 51" HD Projection under $2500
Discussion in 'Displays' started by fernandoAlexand, Nov 23, 2005.
  1. fernandoAlexand
    fernandoAlexand Auditioning
    Nov 22, 2005
    I'm looking to purchase a new t.v.
    I'm not too concerned about the format of the t.v. but after looking at prices I see that projection is probably my best choice. I can't spend more than $2500.00 CDN.
    Samsung HLR5064
    Toshiba 51H85C
    Hitachi 51F520
    or other???
    Any advice would be appreciated.
  2. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Both the Toshiba and the Hitachi can be had for much less than your limit. They are CRT RPTVs. The Samsung is at your limit and is DLP.
    Toshiba 46" and 44" DLPs are also in that range as are the 42" Hitachi or SOny LCD RP unit.
    The CRT sets take a lot more tweaking to look their best, but their best is usually better than the digital displays.
    If you don't tweak ... get a digital RP set.
    Regards
  3. Mike Milillo
    Mike Milillo Stunt Coordinator
    Apr 14, 2003
    142
    fernando, I was looking for a new set as well. Have you looked at the JVC Lcos sets? The 52 inch versions are in your price range. HD-52G786
  4. Jeff Barnett
    Jeff Barnett Extra
    Oct 10, 2000
    20
    The Toshiba you mentioned will be on sale at Best Buy the day after Thanksgiving for $899.
