PhillJones
- Jan 20, 2004
I've been trying to make sence of this issue over on the AVSForum but quite frankly, it's very complicated to sift through the multitude of threads and answer the simple question of which soundcard should I buy.
The M-Audio Revo is out as it doesn't support ASIO and so unless you go to Kernel streaming, you can't get bit-perfect output. I don't want to go the Kernel streaming route as it seams to be complicated and doesn't work with all programmes, eg WinAMP.
I thought the Audigy 2, which supports ASIO would so it but according to a review I read, it also re-samples 44.1KHz sound from a CD. I don't quite understand this.
Does anybody have a recomendation for an inexpensive soundcard with ASIO drivers that will pass the PCM, DTS, DD, or whatever bitstream unmolested.
Cheers,
Phill
Cheers,
Phill
