Reciever Volume Level?
Discussion in 'AV Receivers' started by Norm, Oct 25, 2003.
  1. Norm
    Norm Cinematographer
    Dec 1, 1998
    2,013
    Norm
    I need to turn up my Sony 895 reciever to 50 in order to get to an acceptable level. My old Sony I only needed to turn it up to 16. Any thoughts?
  2. Frank joe
    Frank joe Stunt Coordinator
    May 28, 2002
    155
    yea, depends on what the watt rating is? did you see if they are different?????? and have you set the system up with a sound level meter????????? frank
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Your two receivers are different, and comparing so there isn't really a good answer to your question. As Frank notes, the amount of power difference can account for the difference in volume, but Sony may have changed their scale as well.
    At the same time, check your settings, as you may have something turned on that is dropping your sound levels.
    As long as you are getting the volume you are looking for *without distortion*, you shouldn't worry too much about the difference.
  4. Norm
    Dec 1, 1998
    2,013
    Norm
    Ok,thanks.
    Its just that some foreign Sony tech said it was defective & to return for repair!
