reciever trouble
Discussion in 'AV Receivers' started by Chris Floyd, Jan 25, 2006.
  1. Chris Floyd
    Chris Floyd Auditioning
    Oct 11, 2005
    4
    Back in August my Durabrand ht-395 was hit by lightning. When I turn it on all I hear is a very load noise. I checked all the fuses and there fine. I looked inside and saw nothing that looked burnt. I contacted lenoxx and they said it was the output transistor. Does this sound right? Also if I go about replacing it what does it look like and what will I need to replace it myself?
  2. Jasen Chandler
    Jasen Chandler Stunt Coordinator
    Sep 16, 2001
    91
    IMO, by the time you spend the time and money to fix it yourself you could have bought another durabrand theater unit. I would ask the manufacturer how much they'd fix it for.
  3. Chris Floyd
    Oct 11, 2005
    4
    They told me $30 for them to fix it. I thought about buying a new one but the model I have I can't find.Just the one with the dvd player which has only one other connector.
  4. Chris Floyd
    Oct 11, 2005
    4
    Just an update. I found out it's mounted against the silver heatsink. When I unscrew it it won't come off. How do I remove it?
