I'm looking for either a reciever or something of the similar for under $200. The main thing it needs is 4 s-video and 4 optical inputs. Thanks in advance for any recommendations.
John directed you to a great thread. One of those receivers has almost all the features you are looking for (of those you mentioned). What I suggest is that you go to www.crutchfield.com and search via your criteria. Then look around for the best price. You may not find what you are looking for in a sub $200 but look around and search for deals. Good luck, José
As nobody can give me a reciever in the $200 range that has 4 optical inputs and 4 s-video inputs, I guess I'm gonna settle for the next best thing and just convert one of my optical inputs to digital coax. Anybody know anything about the JVC RX-8040B?
I do think AVR designers, sort of assume once your at 4 video devices / 4 digital devices, your probably beyond this price range. I know of none, that meet your need $200 or under.
best of luck, come on back and let us know what you end up with and your impressions of it please.
I guess I should of mentioned I'm not just looking at retail. If I can find a good used unit in this range with what I need then I'd get that. And I want all 4 inputs to be on back, I hate cords running in front of it.
Actually I need four optical inputs. I've been considering just going with 3 optical inputs and a digital coax input. I've found a couple of those in the price range with 4 s-video inputs. Can anyone give me any info on any of those?
The onk, I believe, has 4 "s" and 3 "o" ins. The reason I gave you the www.crutchfield.com site is because when you do a compare, you can get this info and even search by the criteria you want. Of course at that site the price will be high, unless a special or refurb, which is what you can find the Onk for if you shop around. The onk with 3/4 v/o ins can be found new for $229 or close to that. A great deal if you ask me.
I actually found quite a bit of recievers with 4 s-video and 3 optical and 1 coax that were around the $200 range. I'll edit in all the models when I get a chance a little later today.
Yamaha HTR 5550 YAMAHA HTR 5660 (has all the inputs I wanted) Denon AVR-2803 (more around the $225 area) Yamaha RX-V800 Panasonic SA-HE200 JVC RX-8040B
These are just a few i found real quickly. I'll post a more comprehensive list later.
