Greg Kolinski
- Oct 13, 2002
I've seen various threads on haw much space one should have for the reciever to properly breathe .so to say.Due to the design of my rack,2 shelf,glass front ,open rear..I've done one of the major "no-no"s" I have a 2 dvd players and my Dish box on top of the HK520.:b .One DVD, old Pioneer 434,unit is on top of the reciever,it just takes up space and acts as a heat shield for the JVC player.To add some air space I got some of the plastic PVC pipe caps and painted them and put them under the feet of the Pioneer,so I have approx 3 in of clearance above the HK,due to the HK's depth,it has approx 4 in on the open back side that is not covered by anything.Due you guys think this is ok?? I have never had any overheat issues with it,and are currently thinking about a small fan to blow across the back.think this be enough??
Greg
Greg
