Reciever 125w Speakers 60/80 Or 90w
Discussion in 'Speakers' started by Arvinder, Mar 3, 2005.
  1. Arvinder
    Arvinder Auditioning
    Mar 3, 2005
    3
    I HAVE DENON 4802R RECIEVER WHICH IS 125 EACH 7.1.
    I AM PLANNING TO PUT JAMO SPEAKERS
    CENTER 80/160 LONG/SHORT TERM
    LR EITHER 60/120 OR 90/180 LONG/SHORT TERM
    CAN THEY GO WITH THIS SYSTEM
    ALSO RECIEVER IS WITH IMPEDENCE OF 8 OHM
    CAN I PUT SPEAKERS WITH IMPEDENCE 4 OR 6 OHM
    NEED GUIDANCE
  2. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    The receiver should have no problems with the 4/6 Ohm speakers. You should also pay attention to the sensitivity ratings for the speakers you are looking for. If they are in the range of 87dB to 95dB, you should be good to go. If the speakers have a horrible efficiency rating (e.g. below 80db) you might have to reconsider.
  3. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Most receivers will not like a 4 Ohm load. The 4802 however, can probably take it. You WANT the receiver to be more powerful with low impedance speakers. The receiver is 125 at MAX output, not continuous, which is what the speaker ratings are referring to.
    I can't say I've seen a speaker with less than 80dB efficiency.
