Brett DiMichele
- Sep 30, 2001
- Brett
Hey all,
I finaly got my most recent order from 2CoolTek which included
another round floppie (to replace the last one I screwed up)
and a 3 gram tube of Arctic Silver II Thermal Compound.
The pictures of the HSF show the Arctic Silver II applied
in a neat 1.5 x 1.5 inch square. I measure my CPU and then
masked off the area of the HSF so that I could have a nice
clean pad of ASII where the CPU sits. I also took the time
to polish the base of the HSF Heat Sink to help even out any
anomalies in the surface finish.
So far (40 minutes later) temps have dropped by 2.5 to 3
degrees F and I suspect they will drop another degree or
so after the ASII Stabalizes. Pretty good gain for just a
thermal compound I would say.
I have been in contact with sales at Directron.com and they
have advised me that I can custom order the new all Copper
Heat Pipe HSF from CoolerMaster for a wicked cheap price of
$37.00! This HSF from the comparo's I have seen thus far will
out chill the Thermalright SK6 by a couple degrees and it is
right on the money with the Swiftech Helicoid copper HSF
but at half the price!
The images below are some shots of my MoBo,Wire and cable
layout and you can also see the ThermalTake Active and Passive
DDR Memory Cooling Kit as well as the Sanyo Denki SAN Ace
Fan (HUGE) being used as an auxiliary intake fan when needed.
I would say I have my cable and wire situation all sorted
out. I spent a great deal of time installing nylon expanding
braid to all the fan leads and the speaker leads. The PSU
wires were all hand wrapped in electrical tape (neatly) and
all of the rounded IDE cables are now installed.
Whatcha think? Not bad for a umm "Prebuilt" system? LOL!
Now it's your turn.. Lets see the inside of your modded PC
and the outside too. I have many more mods in store for
this PC. I am painting the whole case, installing a side
window and internal lighting. Why? Because it's FUN!
