receivers (1 Viewer)
DaveGil
Hi. I'm looking for a receiver with 85 - 120 watts/channel that would handle a surround system with 3 front speakers (center, right & left), 3 rear speakers (center, right & left), 1 powered subwoofer and 2 outdoor speakers.
Are there receivers out there that can fit my needs, and if so, what do you recommend? Thanks!
John Garcia
NorCal
I'd say you summed up about 95% of the receivers on the market right there. Could you be more specific?
WHICH speakers? What size room? What's the budget?
DaveGil
I didn't pick out speakers yet. The room is approx. 22x14 and the budget is $500. Thanks.
John Garcia
NorCal
I would recommend you decide on speakers first, as your amplification needs will depend on this considerably.
samtbax
