receivers (1 Viewer)
DaveGil
Hi. I'm looking for a receiver with 85 - 120 watts/channel that would handle a surround system with 3 front speakers (center, right & left), 3 rear speakers (center, right & left), 1 powered subwoofer and 2 outdoor speakers.
Are there receivers out there that can fit my needs, and if so, what do you recommend? Thanks!
EricRWem
Adrik
Right below this area is a forum specifically for receivers and amps. Click on Home Theater Hardware and it's the second option down.
You will have much greater success if you post this thread over there. :)
Jack Briggs
Dave, if you're going to ask about receivers, please post your query in the area designated for such components, which is where the thread is now located. Thanks.
Eddie Horton
Dave, I have a Yamaha HTR-5790 that would do the things you mentioned. I'm sure other people can also give suggestions, but check out the Yamaha. Try their web site, or other retail sites like BB, to find some info.
jemes_kowalski_56
